Wolfie
Well its not so much a work in progress other than I need some ideas for the Footrest assembly ...
The flash washed the colors out a bit, and when I finish some touch ups I'll add a better photo.
It started its life as a hickory long axe handle. I sanded the clear coat off of it and stained it with Ebony stain. The 'straw' is Asian Willow.
I used a couple of those metal screw tightened things you use to hold your dryer exhaust pipe to the vent to hold the stems in place. Cut off the assembly and plastic welded it together then sanded the plastic weld overspill down. After those were in place I poured wood glue down into the tops of the stems.
After all of that dried, I bought some various sized foam balls and painted them reddish brown. stuffed them into the stems and bent them over them, using the heaviest gauge beading wire I could find to wrap the ends together. Then gave it a "hair cut".
I have to note, that I was working on this before that stupid cellphone came out with the same name. Just for the record. :lol
Anyone have any ideas for the foot rest things? I dont have access to anyone who can work metal but if someone out there is good with it and its not TOO much money I'd be interested in your services. Otherwise good ideas for bending thin metal or working with plastics would be appreciated! Or I'll just pull something out of thin air eventually
I'm about to start work on the pads as I am doing a Katie Bell costume for Dragon*Con so I'll add that and change the title as I start working on those if anyone is interested :cool
