WIP Destiny Warlock Helmet - Tengu Operant 3
RS200
Hello all, i'm lewis, a 3D graphic designer from the UK.
this is my build thread for the warlock helmet. it's my first pep helmet and I'm a complete beginner to this world of prop making. its going pretty well so far. I imagine the pep part is the easy part of the build judging by the amount of tutorials, comments and threads i've seen. i've got a strong list of materials and equipment based on research. The only material we struggle to get here in the UK is Bondo. i don't really know what the equivalent is here but I'm a couple of weeks away from that yet.
The pep model came from a guy called Jico from the 405th and his mate grey bear did the physical build. they put together a really professional PDO. Being a 3D modeller i was going to make my own but Lightwave (3D software i use) doesn't play nice when exporting to OBJ + i wouldn't know where to start with unfolding the mesh.
For the Pep part i used 230gsm card / hobby knife / loctite superglue (strongly recommend) / blue tac for temporary sections and a standard A3 cutting mat.
IMG_20141019_185606.jpgIMG_20141020_132259.jpgIMG_20141021_214526.jpgIMG_20141021_222334.jpg
in the 3rd picture you might be able to see an issue i had with a rear panel thats decided to flex inwards. anybody know a fix for this in the pep stage or shall i just smooth it out in the bondo stage?
i still have the attachments to build that really make this helmet stand out. I'm hoping to go for a Chatterwhite shader paint job from the game which is mostly white, black sections and gold detailing. Weathering I'm going to consider further down the project line.
if theres any questions / tips / tricks don't hesitate to offer or ask :]
Looks awesome so far, for the back panel that flexed inwards, try holding in place from the inside and leaving it for a while and see if it sorts itself out.
Good looking helm, I will follow your progress with interest.
As for UK supplies (Bondo), look for a product called Isopon P38.
I usually order mine online, but i understand that Halfords stock it.
I would stick some bracing struts inside the helm to force it into the position you want before applying the resin. You can always cut them out after the Resin stage.
Cheers guys i'll make sure to use to use some decent supports in the resin process. ill check out that isopon P38.
still got the chin and fin sections to make but ill be hardening them separately anyway.
