will a low temperature make resin kick slower?
LeMarchand
I was wondering if resin will kick slower if it has a low temperature. Asking because i need to fill a 400 cc mold and i currently only have fast setting resin handy and i can't fill the mold fully before the mixed resin starts curing and becomes too thick to fully fill the mold. So, if i put A and B in the fridge and mix them when they have cooled, will i have more time befor it kicks?
Thanks,
MArc
Yes, you will gain a few minutes, probably even double the working time on a fast kicking resin...
It will work sometimes. I've even read where some people keep a small 'fridge in their workshops just for their resin.
You can also try chilling the silicon mold as well. In theory it should slow the cure process down withthe resin. I know when you heat the mold it accelerates the cureing time.
Scott
<div class='quotetop'>(vaderman1701 @ Jun 15 2006, 04:31 PM) [snapback]1262155[/snapback]</div>
Scott
[/b]
Hi,
Do not cool your mould in the freezer. I did that once and there was
condens when I casted the resin leaving strange marks on the casting.
Greetings,
BasD
