I need some advice: I plastic frame with Game Workshop figures in it. However one of the bars of the frame broke. This is not a problem if you intend to take out the figures to paint them / play with them, but I like to keep the figures in frame as collectible, and like to see that bar fixed again.
So I was thinking: if I had two small metal half tube parts I could but around that bar and heat it up a bit, the plastic would melt and "fuse" again, and the bar would be fixed. So I'm now looking for two half tubes (both a few centimeters) that together form a tube with an inside of about 3 mm. Somebody know where to get something like that? I tested it on a waste piece of plastic, using aluminum foil twisted around a bar, and this more or less worked (the plastic melted together and was sturdy again), but since the foil was not rigid enough, the shape of what came out was not OK.
All advice is more than welcome!
