Water Slide Decals
UKscout
I'm thinking of using the decal paper that you can place inside a colour laser printer to do some decals for a little project I'm at the moment
anyone else used this type of paper before I order a load? how durable are they?
my friend uses these, he cannot print white, but any other decals work fine - he also seals them afterwards to ensure they dont rub off
I use them for my guitars. They work great. I use the clear and simply lay a coat of lacquer over them to seal the ink, otherwise it will bleed when you dunk them in paper.
I use an older HP inkjet printer with no problems at all.
I believe Laser printed decals don't need to be sealed before immersion in water only the Inkjet type do.
There are different types of paper for inkjet or laser, make sure to get the right one.
Hmmm.....what is this little project you speak of?:angel
Rich
They probably don't need to be, but vintage replica guitar builders use DH's trick.
The original Fender headstock decals were placed after the final clearcoat had dried, and were prone to wear. Later Fender "sandwiched" decals somewhere in the middle of the clearcoats. Some vintage replica builders lacquer the replica decal on the card prior to trimming to add scratch resistance. Then they apply that decal to the finished headstock which keeps a visible vintage decal edge.
1950's examples from "The Blackguard" by Nacho Banos
Example of the new method: (too sterile, IMO)
