Hello,
I am in need of help too !
Your work is truly amazing and since you don’t take anymore commission for now, I think I will give it a try by myself.
I recently got my EFX helmet (after months of fighting with them), but sadly it came badly damaged. See below...
I must say I am a bit depressed. No way I keep it like that but sadly there are 0 chances for me to get any exchange nor refund since I am living overseas...
So I am slowly studiying each step in order to try what you have perfectly done with the EFX ones in this thread. And any help would be really appreciated.
I am sorry to hear that. I do not take EFX helmets because they seem especially prone to damage, from scrapes to Random cracking just appearing.
I’ve discussed my methods many times over various threads, perhaps even in this one. But I will summarize it again just so I can point folks to this post.
Black primer. I use Duplicolor’s Hot Rod Black sandable primer.
2K clear gloss. This is a catalyzed urethane clear coat. I recommend Matrix brand because you can get it in a pint sized kit. If you do not have an HVLP Gun, you can also get it in a can through Spraymax. This goes over the black primer and should give you a nice glass smooth gloss black base. This is the most important step, your gloss black base needs to be flawless. Any and every imperfection will be amplified by the application of the chrome.
Alumaluster. I use an Iwata LPH50 to apply. You’re aiming for about 60% opacity. The real helmets are a lot darker than people think, but I’ve found that bringing it up to around 60% is a nice middle ground.
2K clear again to seal. This is the same product that you used over the black primer. Go back a few pages and there will be a write up on clear coating.
Finally, the upper cheeks get taped off and matted down. I’ve heard a few different things for this, from Omni metallic grey with a little bit of matte clear, to very lightly misted black, etc. I’ve found the easiest way to replicate the look is with krylon satin crystal clear. Just tape the area off and give it a light misting of the Krylon.
From there it is just weathering, colors mentioned above.
I hope this helps a little. For the EFX, I was able to strip it down completely with lacquer thinner, but I wouldn’t recommend it. The helmet doesn’t have super thick clear coats like the Anovos, you can just sand the helmet well, fix any damaged areas and give it a good clean and primer and you’d be good to start the painting process.
