VADER HELMET HELP
TD-0488
I bought a vader helmet made of FG. It does not have an anchor on the top. Just kind of slick. The dome was held on with velcro. Does anyone make the round piece to afix to the faceplate so that I can secure the dome to the faceplate? LMK and thanks
Simple...you can do it yourself. Get two pieces of ABS pipe where the outer diameter of one fits into the inner diameter of the other. Then use Bondo, JB Weld or similar to adhere the two pieces in place...one on top of the facemask, the other inside the dome. Make sure that you cut them to the desired thickness that you need and test fit for position before you bond the pieces in place.
