Not knowing how your rig is setup, there are a number of ways to maximize your heating situation without creating a dangerous fire hazard. Removing the safety shutoff could cause them to overheat, short out, or flat out melt and start a fire. Fire bad, fire very, very bad!
Here are some options:
- Place the heaters in an enclosed, foil lined, box with the frame and plastic making up the top of the box. This directs all the heat to the sheet.
- Use a heat gun to augment the heaters and bring the temperature up.
- Switch to HIPs plastic. It has a much lower deformation temp threshold and will form quite easily.
- Turn one heater on for a minute, then turn the other one on. They will be staggered one minute apart, giving you more time.
- Switch to a custom heating element setup with your own thermostat and temp limits based on the components you select.
Good Luck!
