Maniacy
Hi friends - this is not a prop from a film but rather a prop from a museum, or better yet - from an art gallery.
Tom Sachs 2012 thing "The Sacrifice" (which I believe he made for his own wedding). I want all those things.
(However, the photo on the right is from TSs tumblr, the text refers mainly to the left photo, as it appears there are different things in both versions.)
I need help with:
- Olfa box cutters (can anyone identify exactly which model this is?)
- Mitutoyo 530-101 Vernier Caliper (I can only find a metric version, can you see whether this is imperial? I suspect it should be imperial, not metric.)
- the sharpie
I have no clue about:
- the switchblade on the right (SOLVED)
- vectran scrotum (anyone can point me to this kind of vectran?)
- the pliers
- the two pens behind the sharpie
- the glasses
- the vise grip
- the tie
I can identify:
- Pentel P209-G 9mm drafting pencil
- Pentel P207-G 7mm drafting pencil
- Stanley 69-122 6-1/16-Inch Wood Handle Scratch Awl
- Fiskars 8'' orange handle fabric scissors
- Stanley 12ft Power Lock 3/4" Wide Measuring Tape 33-312, ca 1990
- 1'' Tungsten Steel balls from McMaster Carr (#9598K84)
- "DEBASER" Tom Sachs tie clip (http://tomsachs.org/item/space-program-tie-clip)
- boxcutter lanyard - HERMES Brown Ribbon *Au Fil du Fleuve* *As the River Flows" 2005.
- Golden Acrylics C.P. Cadmium Yellow Medium Golden # 1130-6 SERIES 7 (McDonalds Yellow)
- Benjamin Moore Impervex LATEX High Gloss Metal and Wood Enamel Brilliant Red 309 20 (McDonalds Red)
Cheers,
PS: I know that TheRPF member @asavage is a personal friend of Tom Sachs so Adam if you read this, feel free to comment.
I need help with:
- the sharpie
- the pliers
- the glasses
- the vise grip
- the tie
I can identify:
Cheers,
