Titanfall IMC Pilot Build
gmstrowabarton
I decided to make a IMC pilot from Titanfall and will trying to keep this up to date trying for it to be ready for Dragon-Con in September but we shall see. I have started on the helmet and going for as much detail as I can as I will be molding it once it is done. Armor will come once I get a good foot hold on the helmet and I get the Sintra in for it
Reference of what I am going for
The start of things to come
Just throwing a picture from my collector's Edition
The pep for the Helmet is complete for now
It was then time to harden the pep and I hate Fiberglass and it was cold outside still at this time so I used Smoothcast 321 on the outside and a friend of mine had some onyx that was open so I use that to coat the inside of the helmet.
Weather I has gotten warmer out here so I have started on the bondo work and in between I have started work on the outside parts for the helmet
Once I went and got a new Dremel flex shaft as who ever used it last time lost the inside turn shaft making it useable I was able to start detail work somewhat after sanding with the palm sander
Jackal
Re: Titanfall IMC Pilot Build (picture heavy)
Looks great! Keep up the good work.
jamesmcintoshjr
Pretty sweet, where'd you get the pep file? Or even better, in-game models... wouldn't mind tossing a few things through my replicator.
That collectors edition titan is pretty friggin awesome, I'd have popped for that if it weren't so pricey.
gmstrowabarton
Thanks Jackal
The pep file I got over at another forum the 405th.com and they do have .obj files from the game. Here is a link to the thread on that forum **Official** Titanfall Pepakura Thread
Yeah the only reason I got the collectors was do to me saving some money off to the side each month after they announced it
jamesmcintoshjr
Ahh thx so much! With proper game refs like this I can refine in 3d max to generate a hi res source for printing, and it will be proportionally accurate. will share back if I make anything!
gmstrowabarton
I have spent a few hours outside today slapping bondo, sanding bondo, and cutting holes in the helmet. I did have some spots I have sanded through the plastic but I have filled the spots in from the inside of the helmet with apoxie sculpt since it was easy and will be hard by tomorrow when I go to a build party at a friends house to work on the helmet and possible other things as my sintra might have come and I will get it at the build party. Here is the damage done today:
I wanted to get the edges rounded from the sharp folds it was in the pep so added some bondo here
After lots of sanding and grinding
Some of the repairs with apoxie sculpt on the inside
gmstrowabarton
Oh my, so nice.
Thanks. :)
Man this is looking great! Keep up the good work!
Thank you, working on it lots of smoothing to go
Mold it you say? :D
Yep trying to get this as close as possible to the 3d model in the game/art book then mold it so it wont weight as much as it will once I am done smoothing it with bondo and apoxie sculpt and and if people are wanting to purchase then I will see about selling some then.
So have a small update the weather didn't let do any outside work the last 2 days. I got so bondo work on the front top of the helmet and it sanded down. But I found a issue this weekend when showing someone how the external parts fit to the ear pieces to them. They are sticking out to much I then rechecked the 3d models and found that since the pep file had the ears separate they had extra on the edge so I have been trying to figure out what to do either extend the external parts or cut the ears and grind the inside edge down. I will have pictures showing what I mean. I think I have decided on cutting them so it matches to the 3d files.
This the ear area that is the problem i ran into in the first 2 pictures the red line is where I need to cut and the blue is just showing the point of the main helmet edge. The 3rd picture is from the 3d model in pep the red line shows where the red lines in the first 2 picture should be and the blue line shows the same helmet edge from the first 2 pictures.
gmstrowabarton
Looking good here's my finished helmet made my a mate and painted by me
Nice Militia pilot, how was the helmet to see out of I have wondered how this helmet is going to be.
Here is another update I started on some of the details and also cut the ears off and grinded them down I will get them reattached later on. I printed out some of the pep files with the textures on them to use as patterns for the details used sharpie to mark the spots on the helmet
Here I use some Apoxie sculpt for some details and to fill the edges on the side since they have gotten a bit low from the sanding. I also found that the rectangle I had cut in the visor was too wide so I filled it to the point it should be.
I finally started to get some of the soft parts I ordered and the clear visor and the mirror tint for the helmet still waiting on the leds I have purchased for the helmet. The uniform I will have to make since I can't find anything that would be close to it. I might start the armor soon but most of my time is going to the helmet first I have some of the sintra in 2'x'2 sheets and some patterns for it cut but needing to be assembled once I figure out the angle cuts for attaching the sintra.
So I cut the ears in the 4th picture here you can see the pep piece that was the item I tried before and found the ears were wrong in this picture it is how it should be before the cut it was about half an inch from the helmet so the ears will be how they are in the game model.
I have cut in for some of the panel lines that were shown on the helmet textures that I pattern out first. Next steps after this I will be spraying primer on the helmet once the weather changes from about the rain to no possible rain.
mattrendar
Stuffs looking great . For my visor I used a plastic face sheild from Home Depot then used a metallic car window tint . Can see through it perfectly . I'll post pics later . For the uniform you should just use a grey flight suit .
gmstrowabarton
Ok about the same stuff I have for my visor but I am going to try and light mine up with blue leds and be able to change them to amber. The uniform I am trying to go as close to same thing and looking at the 3d models it isn't a one piece flight suit but a 2 piece with a vest over it for the armor to attach to I also a few sewing friends that go to the build parties and will be getting their help on this.
Small update the weather was rainy until today and it was nice and warm for bondo so I started to add in details to the chin area and the side areas around the temple area I ended up taking out a lot of the bondo detail I had on the left side and just redoing it I didn't like how it was looking before compared to the right side.
I also cut out some more detailed on the top of the helmet I will cover the holes from the inside with styrene when I have the helmet outside all ready
this piece is just a pain trying to get right will see how it looks after some primer since I think the different colors are messing with how I am seeing things meet up
Primer before the sun went down
jamesmcintoshjr
so using that link you provided to the 405th pep files, one of the guys was ripping the game models for the weapons. I managed to get an OBJ of the MK5 smart pistol, that was totally mangled, but used it as a proportional reference to basically rebuild it in MAX. Did a size-test print last night, thanks again for the link!
This is just the main form, a lot of the details and switches will get printed separateyl and applied, as well as the light under the barrel, that piece will be made to work and slip on as it would in real life. The grip is also hollow allowing for a magazine to be loaded. I plan to do the final one with some translucent filament so I can have the bits on the iron sights light up like it does in-game, and I'll make a magazine that basically just has batteries and LED lights in it to make that work.
gmstrowabarton
Oh that looks great I have been trying to think what I can make or modify to make the MK5. I haven't been able to work on my build for a few weeks do to RL between getting the house ready for my fiance moving next week and then someone decided to kick my front door in last week.
