elro
Was adding this here, and somewhat answers Magneto's question.
But ive come up with a method making pep solid (glass, and filler) that is completely safe and non-toxic. But do note its not exactly the cheapest method.
From what ive learnt / questions ive asked people with experience with the following materials, the combination of the two would be great on PEP/
Im just going to shorten this but ;
Glassing : Bunyan films Aqua glass (with their cloth), initial cloth and resin layer inside, with 2 extra coats of resin.
Filler - Apoxie sculpt (I found out recently this stuff is actually not toxic, im sure others have used this stuff. Its not the cheapest material around for the quantity you get, but since your making a flat surface all over it does go quite a way + It sets very solid.
One of the biggest advantages is that it is in putty form - It has a 3 hour set time which allows you to get the surface flat and smooth as possible to minimise waste when sanding back (If you do a good job of apply it, you can pretty much go straight to the later sanding stages).
Aqua glass : Aqua-Resin Prices
Apoxie sculpt : Apoxie Sculpt
(MAGNETO = USE THE APOXIE SCULPT - work it just like clay, but it will set solid for you
