The Amazing Spíder-man suit 2 HELP
Discussion in 'Marvel Costumes and Props' started by Caio, Aug 27, 2015.
Tags:
  1. Caio
    Caio New Member
    2
    Hey guys, what's up?
    A few months back, me and my friends decided to organize a Halloween Party, and I decided to go as Spidey. So I bought the fabric and paid a dressmaker to sew the suit. That's how it is currently:
    IMG-20150826-WA0008.jpg IMG-20150826-WA0009.jpg IMG-20150826-WA0006.jpg IMG-20150826-WA0005.jpg IMG-20150826-WA0004.jpg IMG-20150826-WA0003.jpg IMG-20150826-WA0007.jpg IMG-20150826-WA0002.jpg IMG-20150821-WA0019.jpg IMG-20150821-WA0013.jpg IMG-20150821-WA0017.jpg IMG-20150821-WA0018.jpg 20150827_191417.jpg 20150827_191413.jpg 20150826_193358.jpg 20150827_191423.jpg
    I have a few problems now:
    1) How do I posicionate the lenses?
    2)What do I use as model to puff paint the head (and the body as well)?
    3) What is the best paint to use for the webs?
  2. cha0tic
    cha0tic Active Member
    467
    Your next move from here would be to either free hand the webs or get a template and trace them on to the suit using a marker, and then puff painting over them. And for the blue I would add a brick pattern there which you maybe able to trace as well.
  3. Caio
    Caio New Member
    2
    Thanks, but should I use something like a mannequin to trace or it isn't necessary?
  4. cha0tic
    467
    Like putting the suit on a Manny and then tracing the webs on it? I'd recommend it for sure.
    Sent from my SM-N915V using Tapatalk
    Caio likes this.
  5. Caio
    Caio New Member
    2
    Exactly, thanks man. I will look for a Manny and continue my suit :)
  6. cha0tic
    467
    A full body can go over $100, if price is a issue make a duct tape manny. Much much cheaper but you'll need help doing it. :)
  7. Jeck13500
    Jeck13500 Well-Known Member RPF PREMIUM MEMBER
    917
    I would not make the brick in blue part because once the suit is assembled, it's almost impossible to get something great, moreover this will take too MUCH time ... By the way, free hand the web by using a pen is a great thing like said cha0tic.
    Personally, I don't use a dummy, hardest to work on, I'm working on flat surface, but you need to do as you prefer/want
    Jeck13500
  8. Jeck13500
    917
    Last thing, buy a faceshell dude, you will be able to put the lenses easily ;)
    Jeck13500
  9. Caio
    Caio New Member
    2
    Yeah I thought it would be almost impossible to do the brick kkk
  10. Caio
    Caio New Member
    2
    I thought about use a faceshell but I want to remove the mask easily, like peter do it in the comics, so I decided to try without it first.
  11. Caio
    Caio New Member
    2
    Hey guys, I'm making the front spider now, but before make it in rubber **** I made on E.V.A. to compare the size:
    20150903_194747[1].jpg 20150903_204811[1].jpg 20150903_210218[1].jpg 20150903_210325.jpg
    so what do you guys think? the spider it is too big? I'm 6′4″ so it has to be a little bit bigger than the majority
  12. Jeck13500
    917
    I was like you before, and then, I've discovered the faceshell, the face looks so much better with it ;)
    Jeck13500
  13. Caio
    Caio New Member
    2
    I know that now I have to draw the webs, but i have a doubt: What kind of pen can I use in lycra/spandex? Do you know? something i can wash after puff paint.
  14. cyup93
    cyup93 Active Member
    242
    I think you have sewn it too quickly.
    If I were you, I would have drown the web lines first, traced them from a picture or the computer screen with a ruler and a marker.
    I am wondering why would need a washable marker, because when you puff paint on top of the line, it will become invisible.
    But there are washable inks which are water based. http://www.stubbypencilstudio.com/product/LIQ_ECOLORGY8/Washable-Markers/
    I guess it is easier to correct mistakes.
    if you want to draw the bricks on the red part, do them first before you do the web lines.
    I would recommend you to use a metallic black marker or a silver marker (if you dont find metallic black) to do the blue bricks.so you do not need to puff paint them in the end.
    puff paint without guide lines is harder to control and you can not use a ruler as a means of help.
    At this stage you can use card board pieces inside your suit to make it flat and easy to work on (on a table).
Share This Page
