TARDIS Pull To Open Door, completed
deck5
A russrep sign from the recent run-- I built a door for it. Just finished putting the final touches on. I'll be hanging this on the wall, unless the urge strikes me to build another Tardis!
attachment.php
Re: Pull To Open Door, completed
That looks awesome and not an obvious prop (one that the average joe public would know of) to decorate the house with!
That puts mine to shame. Very nice work. Where did you get the door pull from? I had thought about adding the hinges as well. Now that I saw yours I think I have to.
Thanks for the link.
Note that those handles have some magical coating on them that's really, really, really hard to sand down. It's a nice feature, but not when you want to weather a thing. :)
Also, the hinges came from Lee Valley.
That is truly a thing of beauty!! I am hoping to make something similar as the lid to the box where I keep my Doctor Who collectibles. But I doubt I could make it as perfect as this.
I've been asked a few questions about the build, so I thought I'd post the details of the construction & painting here.
The dimensions of the door overall: 14 1/8" wide, 16 3/16" tall, and 1" thick. The frame is 1 3/8"-wide all around, 1/2" deep, glued on a 1/2"-thick plywood backboard. The sign has a 1/8"-thick hardboard behind it to bring it forward a bit.
The frame is built of smooth pine, so I made faux raised grain by running a rounded point repeatedly along the pieces of wood. I also distressed the edges and corners.
I used two coats of paint on the frame -- a really bright blue/turquoise matte tinted primer, and a matte cobalt blue top coat. The cobalt blue is rubbed off with a dry cloth as soon as it is applied. Once dry, I rubbed graphite powder into a piece of cardboard, and rubbed it flat against the raised grain.
To darken certain areas further, I used black tempera pigment powder applied dry with a paintbrush, then blown out, then rubbed with a damp cloth to get what remains to merge with the finish.
All was then sealed with a matte clear coat.
The sign itself was weathered strictly with paint, no actual damage was done to the surface. A very light application of Testors detail enhancer applied with a rag, scrubbed with a soft nylon brush to remove all but traces, and then several dark shades of tempera pigment powder dusted on that while it's still drying, and then rubbed down with a cloth.
The hinges are set into recesses made with a chisel, screwed shut, and painted & distressed. All the screws are given a bit of age, too.
Let me know if you have any questions!
