Suggestions for head armature please!
Discussion in 'Replica Costumes' started by enygma214, Feb 27, 2012.
  1. enygma214
    enygma214 New Member
    17
    Hi all. I'm still pretty new here and I'm working on a couple of things that hopefully I'll be showing soon.
    But first things first. I want to do some clay modeling for some mask ideas that I have but I'm not sure if I should buy a pre-made armature or make one of myself. I've found only one that seems decent and its the one from CFX. I also found that you can purchase it at MonsterMakers. The problem is of course that the brow is 22" in circumference and I've come to know that most people are in the range of 23"-24". I personally am 22 1/2".
    So if I later decide to make a run of my sculpts should I stick with the larger size or settle with the CFX 22" size? Do you guys know of any place that I can purchase one with a bigger head? That would make it even easier.
    CFX Armature:
    [​IMG]
    All advise is welcomed! Thanks all!
  2. enygma214
    17
    Anyone? Any suggestions? :confused:cry
  3. G33k
    G33k Member
    191
    One thought...the ready made form can save time. If you are forming over the head in clay, and you build out your sculpt enough, your finished piece will be larger than your original armature head anyways right? Depending of course on wht method, and how thick you cast your final piece.
  4. Wes R
    Wes R Legendary Member
    6,750
    I was actually going to suggest the monster maker's one too. I just wish they made a female one too.
    Edit: I just checked the cfx site and glad they have female. The armature price is higher than monster makers though. I'd probably buy the displays they offer on cfx and use it as an armature.
  5. enygma214
    17
    Well I decided on the monster makers armature. I should be receiving it soon. I already have some helmet/mask ideas brewing. What would you guys all like to see if given the chance?
    Sent from my iPad using Tapatalk HD
  6. micdavis
    micdavis Master Member
    3,326
    Is this really an Armature?
    I mean isn't it just a bust or a head.
    An armature is a mechanical skeleton used for stop motion animation.
    ...or sometimes the wound bushings of a motor.
  7. Finhead
    Finhead Sr Member
    1,307
    Your thinking of one definition of the term. Here is another, or the one being implied here.
    A framework serving as a supporting core for the material that is used to make a sculpture.
  8. micdavis
    3,326
    Yeah, sure, it's being implied. I just think unless the base is more of frame work than a bust or life mask, it really isn't. Never heard of head being referred to that way is all. Seems different altogether so it should be called something else.
Share This Page
