Just started the 1/24 B-Wing which I picked up a few years ago. Misplaced the instructions but thanks to the pioneering builds posted all fantastic resources if you wish to attempt this ungainly yet beautiful beast.
I’m going to try and modify it to be as close as possible to the orange spot version. Had intended in making the rear wing recess but will now will fill it in for a smooth wing as per original. I have the ambition of modding the nose with the correct gun placement recess cut out along with revised side panelling.
Will have lighting and might attempt at making the cockpit rotate just a quarter so it can assume horizontal and vertical flight – so model can be mounted accordingly on an internal aluminium armature. A lot of clean up to do and parts to straighten/repair/scratch out due to warpage from boneyard storage.
I’ve drilled out the wing thereby moving the centre of gravity a little closer to the main centre intake section. I’ve also drilled out the dorsal mount that connects to the cockpit and managed to excavate a fair amount of resin overall. Even the lower gunpod has been drilled out so she’s a lot lighter as a result and hopefully would be able to assume a number of poses on its pseudo-panavise mount. Furthermore the armature will extend straight through the entire length of the hollowed wing so no danger of sagging
Anyway…..more photos to follow
Lighter wing
To fill in recess
The ‘sunfish’ rotating cockpit…nasty seam need to take care of that…..
Lighter wing
To fill in recess
