Steampunk Sonic Screwdriver Project
Straker
Hello!
Well, some people were rather interested in my recent hardware built, Steampunk (sort of) Sonic Screwdrivers I've been working on as a project. I plan to make a short run of these to sell, but in the mean time I thought I'd show you folks my progress.
This is my first attempt, what I like to call the Mark 1 Sonic Screwdriver:
It was based off one made buy a guy named Jared Axelrod who does Steampunk type work, and I actually did order one from him, however after god...7 months of waiting, what I had gotten was a wooden dowel rod, with epoxied parts on it...not to knock the guys work but man, there was no craftsmanship there. so I decided to make my own with an actual electronics system and a functioning switch. Many of the parts had to be hand lathed however, since I don't have a lathe a drill press, precision files, a caliper, my eyes, and a lot of test fitting had to be used. I topped the whole thing off with a blue jewel lens from an actual toy sonic Screwdriver.
It is a good piece but it needed refining, so I took it apart and reworked it a little and got this:
I like to call this version my Mark 1.5 Sonic screwdriver. The main differences now are the emitter head has a smaller blue jewel lens that fits into the inner sleeve allowing free range movement of the outer adjustment nut. I actually had to put the old toy lens on an expansion bit, pop it into my Dremel and sort of file the lens diameter down till it fit, then sand and smooth and polish it out. I really wanted this lens to be small like that to allow the outer nut to move along the heavy thread you see on the neck of the sonic because this allows for a "control" setting system for sonic field resonance, strength, and intensity.
Another thing I did was to remove the fine threads from the outer emitter ring nut to give the parts a cleaner look to them and distinguish them just a bit more from the plumbing parts that makes this sonic up. The result makes the whole device look more original and add just that tiny bit more authenticity to the prop.
Still, I decided to push things a little further, and even though it is still incomplete, lacking a button and some decorative rivets, I made this one:
This one is my Mark 2.0 Sonic Screwdriver and is being made for 0neiros here on the RPF. The new differences are the emitter end has an elongated inner sleeve piece for the emitter jewel to sit in as well as the different and more elaborate decorative vented slotted piece soldered in the butt end. There is also a small brass plate for the activation button to be set into which will have a couple small brass rivets in it where the pencil marks are. I also plan to add a couple other small embellishments to it here and there.
Then there are my plans for a small finger ring, sort of like the one on the River Song Sonic Screwdriver from the fourth season of the new Doctor Who series only using your index finger instead of your pinky finger:
I would want to make it out of steel and have 1/8th inch for the main ring piece and 1/16th inch for the mounting brackets. I also had an idea to remove the bridge section between the two mounts to put a small hardware based tube made of copper and brass parts to add a conduit look to the whole affair.
Lastly, I am experimenting with sound boards taken from toy Sonic Screwdrivers, so it will actually have sonics.
I figure that if I can, I may be able to offer costumers a Sonic Srewdriver, made of metal that they can carry on them, will be durable and that way if dropped they don't have to worry that it will be broken. I know I'm no Russel Brown or anything, but, if done right I may be able to sell these from $50.00 to $100.00. I am also hoping to find a way to get the blue lenses in the diameter I need from somewhere, and I wold KILL for them to be made of blue or frosted clear glass.
Update: I'll have to charge $100.00 for the Mark1 styled sonic I'm afraid and $20 for the Mark2. The reason is that the build process is longer than i would like due to lack of a lathe to fabricate some parts as well as the cost of parts in total and build and refinement time.
Anyway, let me know what you guys think. ^_^
Very cool:cool Just looking at the pics, kinda made me think of a lightsaber:thumbsup I'd love to have one:)
That indeed is a beautiful interpretation. :thumbsup
Did you ever consider using leather instead of the rubber rings ?
Yeah it does have a lightsaber feel to it. XD It's umm, a bit too small though. At 5 inches it's more like a Light-icepick really. XD
I have actually. I just haven't experimented with it just yet...mostly because I haven't worked much in leather. XD i plan to use blue rubber rings on Oneiros' Sonic though, IF i can get dark blue rings. Figured that would give it a more regal look to it. Still, I am open to trying any upgrades and the best part is, if the owner chooses, they can remove the rings and replace them with whatever they want since I don't glue them in place. ^_^
Beautiful! Clever design that really captures the feel of the new SS; the brass also echoes the feel of the new TARDIS control room as well.:thumbsup
You know, funny you should say that because I sort of pictured this as a later version of the Sonic Screwdriver used by the 8th Doctor before the modern type. I had an idea for a story where the 4th doctor left one of his old sonics at Unit and it was dissected and upgraded and given back to the 8th Doctor who built this from it and then after regenerating, the 9th Doctor built the modern from it. I sort of like to think of this as a bridge between the classic and the modern version.
Glad you like it too. ^_^ I'm actually very glad to hear that so many people like this design ^_^
Simply beautiful! When you offer these for sale, I'm definitely in!
Excellent! I'll be sure to post when i have at least ten of these for sale with a link to either the eBay page or to the Junkyard for direct sale, which seems to be the best place as my main customer source is coming from here XD I hope to have them all ready this year, though it will be a slow process since I'm doing all the work myself.
very nice work, really like the look of it. depending on when you bring them out I may be in for one.
Watch for an update post this year. I want to have at least ten of these ready to go before I sell. Nice thing is though, even if you don't get one of the first ten, I plan to use the money from those ten to build ten more and then do the same when those sell. ^_^
Just a question. Will the part with the finger loop be removeable and reattachable?
Excellent question. I plan to use screws to attach everything so it will be able to be taken off, well, it will have to be anyway since you'd have to remove the back section to replace the battery, but thats as easy as two screws and a twist so no problems there. I may not be able to make that part for my initial run though. I need a steel cutting capable band saw to cut the parts so I have to outsource that.
Cool, thanks. I'm eager to see how it turns out and can't wait to get my hands on one!
