andy19422
This is my first ever attempt at making anything so please be gentle :lol.
I am using a resin casting from a screen used chevron to base my measurements on and lots of pictures I found on Google. I am also using blueprints from TEE, thanks mate.
I will be making the back panel that the chevron fits onto out of 10mm fibreboard then using 4mm foam to build up the shapes. I can then use this to mount the chevron too and screw the whole lot to the wall. This will also seal in the light to the chevrons two parts.
The wings are made from 75mm foam then cut in halve. I used a string with a pen loop to get the radius right. These are the first set of wings but I will make another set when I know what the end thickness of the whole thing will be. The lines on them were done using a dremal freehand, but when I do the next set I will make some thin ply guides.
The centre piece of the chevron was made using 33x20 pine then foam glued on. I have still to finish it and then fill it but I don’t think it turned out too bad. The amber panel will be the same resin that I will use to remake the V part. Feel free to point out mistakes and offer some suggestions.
By andy19422 at 2011-10-18
