Spidey neck issue
Discussion in 'Marvel Costumes and Props' started by WebSlingingHope, Sep 2, 2015.
  1. WebSlingingHope
    WebSlingingHope Active Member
    341
    Hey all, you may or may not have seen my seven-piece amateurish Spidey build before on here, but that's okay! That's not the problem I face now, the problem I do face is the neck area.
    Does anyone have ideas on how to make it more snug fitting, it's rather loose around my neck and I don't know what to do.
    Sent from my SGH-I337M using Tapatalk
  2. exo95er
    exo95er Active Member
    341
    I've heard people use magnets...
  3. WebSlingingHope
    341
    What, how?
  4. thejakemoore
    thejakemoore Well-Known Member
    635
    It would help if you posted photos so we could see your specific problem.
  5. Hazmat
    Hazmat Well-Known Member
    566
    This only works if you're a robot.
    exo95er likes this.
  6. exo95er
    341
    Attach on mask's neck and also on the suit.
    WebSlingingHope likes this.
  7. WebSlingingHope
    341
    I'll try that out, is that how Tobey's suit worked if the mask needed to be detachable?
  8. exo95er
    341
    Can't say if that's how the suit worked. It's all movie "magic" - there's the one piece suit with the mask attached to the suit so that there's no seam line, and then there's the suit without the mask for those shots where Peter can show his face. Most people go with the mask attached.
  9. sp1derman
    sp1derman Sr Member
    1,356
    The tasm suit used and invisible zipper on the neck to tighten it around the neck
Share This Page
