RICHIES ARMOR
Ok Ive been working on a way to add a "Vent Purge" system to our ALIEN space suits similar to the screen used costumes.
In the film a gas is purged from the suits on about 5-6 second intervals escaping from the top of the helmet(s) as a fog.
Ive rigged up a system using CO2 AKA paint ball cylinders, a nitrous high pressure selenoid , high pressure quick connect lines and a small 12v motor that turns about 10 revolutions a min. This triggers a microswitch that fires the selenoid.
Im running into a couple problems tho that I need advice with:
1) The CO2 is so cold that its actually freezing up the lines.
2) Im using a 20 oz CO2 cylinder but it runs out very quickly.
Im needing a gas that one will not spray out under such high pressure and two wont freeze up the system so quickly if at all.
Suggestions??
See video of system at work.
YouTube - ALIEN Space Suit purge system
Richie
Suggestions??
Richie
