At the very top of the ship is the 2 level “Command Control Center”. The top level is a bit larger than the bottom.
Since the opposite sides have windows, am using separated LED strip mounted on the bottom, which will
reflect light into the white "ceiling”.
I added some small details to the "window walls" to create more visual interest. Bringing together the pieces...
Each floor was assembled with window strips, styrene diffusion, and white paint for bouncing the light around.
The top floor power feed was soldered to the bottom floor.
Testing fit and details...nothing glued. Finished for now.
We all make mistakes. An "almost" disaster occurred during a photo test. I discovered that the base support rod
(1/2" CPVC pipe) was going to be too close to the antenna array at the bottom. The rod was obliterating
the camera view to the point of unacceptable.
I had only one option, which was to re-cut a new hole in the bottom plate and move the array as far back as possible.
This required ripping out details, cutting a new hole, and then covering the old hole with new details.
In process of the move...
Set in temporarily, much better.
Till next time...work on the base support stand begins.
