Space above and beyond marine costume
spacemarine
Just thought i'd show a few pics of my space:aab marine costume,
I still have all the big parts to get (helmet, rifle, re-breather pack)
they are been worked on by wilco models and scifihero.net
Parts i have...
Parts that i have that aren't pictured, grenades dog tags and M590 rifle sling.
I still have a few mods to do to the armor........... Still a long way to go on this project.:wacko
SM.
Space:aab Helmet cam Tutorial
First off you will need the following:
1 Resin helmet cam.
1 Monocular. (look on ebay)
2 Screws to hold everything together.
5 Nuts and bolts to attach cam to your helmet.
Pic 01 Monocular from ebay
http://cgi.ebay.com/8x21-Monocular-Telesco...1QQcmdZViewItem
Pic 02 Cam replica from Dan
So to start off with you will need to cut the front of of your replica helmet cam.
Cut off above the red line.
Your cam should look like this once your have removed the front section.
You will need to fill and sand any marks caused during the cutting.
Now you need to unscrew (by hand) the viewpiece and the lens housing, then unscrew
the 4 small screws holding on the 2 silver triangle pieces.
You will need to keep the black middle section, 1 of the silver triangle pieces
(with the 2 small screws) and the lens housing.
Monocular Parts:
You will need to sand down the thread that the viewer screwed into to get the centre
section to sit flat against your cam.
Now you need to prime the cam, centre section and silver triangle.
Then paint the centre section black and the cam and the silver triangle olive drab.
Position the center section against the cam so you know where to drill your holes to
hold the centre section in place.
Use 2 screws to hold the centre section in place.
Put the now olive drab triangle back in place and screw down.
Then screw your lens housing in too.
Now use the 5 nuts and bolts to attach the cam to your helmet and it should look something
like this.
Space Marine..........
