Space: 1999 Hero Eagle miniature half-scale replica
phase pistol
Presenting: the 1:48 scale Eagle from the futuristic 70's TV show "Space: 1999"! Built for me by SDStudios from the Round 2 styrene kit.
https://www.flickr.com/photos/karltate/albums/72157671642429436/with/28634949951/
Much time was spent removing seam lines and fixing other defects in the kit. The complex and subtle weathering was also time-consuming, but the reward is a beautiful half-scale representation of the show's hero 44-inch Eagle miniatures.
The show's three hero Eagle miniatures were repainted several times during the show's two seasons, and they rarely look the same from shot to shot. These specific markings and gray panels covering the Eagle were designed by me after weeks of research, and printed as dry transfer sheets (so that Steve would not go crazy placing them all!).
Powerful magnets hold the passenger module in place. Landing gear supports are machined brass, and the outboard fuel pods are filled with resin for added weight. Real glass windows (microscope slides) are used in the upper Command Module.
Mike Reader's aluminum sensor dishes were used in the Command Module. The many rocket engine bells are turned aluminum, from Round 2's accessory kits.
The landing pad base visible in some shots is a 25 x 12" graphic designed by me from study of rectified screen grabs of the show. Steve had it professionally printed on heavy photo paper with a matte coating for durability, and it's attached to a custom-cut plastic sheet to form the model's base.
- Karl
Beautiful results! You're certainly doing justice to that wonderful space transport:cool
Excellent,...I'm building one of these also,.....my thread & others are over in the General Modelling section
J
