imaginager
One of my longstanding studio scale goals has been to build a Snowspeeder with servo-controlled upper and lower air brakes. I remember seeing the "Making of" special for ESB as a kid and being completely taken with the moving flaps and pilot's head.
So, the only thing I knew about servos before starting this build was that I'd need to use them. :lol
About the middle of December I purchased an Arduino Uno micro-controller and a couple of E-flite servos, just to dink around (HiTEC HS-55s are installed in the model). Then, I thought, I'd start on the hard part: developing the code. My requirements were primarily to control the servos so they could move both simultaneously and independently of each other, at variable speeds and throw.
Turned out the code only took a day to work out. The actual hard part was developing the hinges for the flaps - these aren't some off-the-shelf products from the local hobby shop. I had to design them in CAD, have some of components laser cut (because of the tolerances), then scratch build them. There may have even been some expletives and swearing.
But, enough whining from me. I think the initial "on-board" test of the upper flaps went pretty well. I posted a teaser of the lower flaps in my EFX TIE Preorder rant thread, earlier.
Snowspeeder Upper Flap Test 4.1
And, here is the practical test for the lower flaps:
Video - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
