Shuttle Tydirium - Ogi Parts Map
Ogibendogy
I've been working on a new parts map for the shuttle. Probably around 80-90% complete but have been having trouble taking it over the finish line, so time to make this a group effort. Color coding matches those used on Slave 1 parts map, and as before, I'll keep this updated about once a week and will keep the most recent PDF in the top post. Thanks in advance for the help and enjoy!
  • Shuttle Tydirium Parts Map_Ogi Ver 01.pdf
Nice and looks good.
Although, that first picture is from the full size set, and therefore everything is not correct compared to the filming model. Like that cockpit.
Always wonder how that got so messed up anyways.
All the rest go look good.
Great timing. I was just looking for a parts map yesterday but noticed none existed. I was just going over the Merlin models kit looking at details. Thanks for making these!
the big purple thing, i think its a Tamiya 1/32 F14 Fuel Drop Tank with added "details"
The purple part on the forward guns are Tamiya 1/35 German 20mm Flakvierling 38 mit SD.Ah.52 - the gun receivers with barrel removed
the yellow main guns, they could be brass, but i think there is a Ferrari part loking exactly like that, maybe i can find it
The big purple shields should be Tamiya 1/35 German 20mm Flakvierling 38 mit SD.Ah.52 - modified a little
The Tamiya Flakvierling Shields are way too small.
Front Shields on the Tydirium Model are scratch built styrene.
Also, if i remember correct, the large discs/domes of the wing guns are from the Sealab.
The sealab part I believe you are talking about has one large and one small hole molded into it. If that's the part they used they would have had to modify it significantly. Given that I would lean towards a plastruct part (but still not totally sure).
