Shotgun body help
helix_3
So I found a great base for a futuristic shotgun:
Only problem? It's attached to my vacuum cleaner! Where is the easiest place to get pipe of this shape and size? Is it possible to bend PVC, perhaps?
You can heat pvc and bend it, same with steel and other metals but usually with a torch. You may be better off starting with a cheap airsoft than spending the same amount on trying to make somehting from scratch.
