Scout Trooper - Endor 1:12 scale.
Hemble
Hi All,
Recipe
Scout - is from Hasbro's BS 6" line and has had the joints glued and puttied up and then he was painted and weathered using Vallejo paints and pastel chalks.
Base - is made from Bandai stands that come with the kit and then foam was added to the top and then a balsa wood frame was added.
The tree trunk I got from the yard and the smaller trees are from Woodland Scenics. The small ferns are from MIG and the grass tufts are from miniNatur, I used 1:1 scale fake ferns for the large ferns and cut the end off and used them.
The smaller ground plants as well as the water plants are from JoeFixit Studios, I used Woodland Scenics Realistic Water for the water itself and once dry I mixed a little Vallejo German Camo Medium Brown with some Realistic water to do the muddy water effects.
The moss on the trunk was done by mixing spakfilla x 1 tablespoon and fine sand x 1/2 teaspoon and mixed it with some PVA glue and light green paint and added it to the trunk.
Ron
