Sabine Build (with Adventure Gear!)
lilshrt4atroopr
Hey guys! I'm new here have been lurking for about six months now. I've had several failed projects but I'm hoping to see this one through as I would like it to be done in time for this year's cons.
Below are some pictures of the armor pieces I made from aluminum. I picked aluminum because it's lightweight compared to normal sheet metal but it still has that nice authentic look of armor. I cut the aluminum with heavy duty shears which was a bit tedious. Then I went back and filed off the burrs using a flat file for the edges and convex curves and a round file for the concave curves. There were some scratches on the metal I polished out with my dremel and some polishing compound. This was my first time using my dremel; you basically treat it like sandpaper and start with a rougher grit compound and rubber tip, then move to buffing wheel and brass polish. I'm pretty pleased with the way it turned out. The whole process took a few days to complete.
I will post some more pictures once I get done painting. I haven't started on the adventure gear yet but don't worry it will come! I'm going to make this a bit like a tutorial so that anyone wanting to make this can learn from my experiences and save themselves some trouble by replicating parts of my process if they desire. Starting out with a big project can be overwhelming so I hope I can help someone else out!
Resources
http://rebelsreport.com/2014/10/27/cosplay-101-eva-foam-vs-sintra/
http://eitanya.deviantart.com/art/Downloadable-Sabine-armor-templates-483881333
lilshrt4atroopr
I'm not quite done with the armor, but I thought it was time for an update. These are some pictures of the aluminum after being painted. I used a violet color for the first coat and then went over it with a fuchsia over-coat to try to achieve the almost two tone color of Sabine's armor. I let the violet undercolor show through in some places. I used a paper towel to create the battle scars by literally ragging the paint off in some areas. For the chest piece with the rebels symbol I made a pattern which I used to transfer onto the armor itself. I used tape to refine some of the lines but I left some of them rough because I felt that created the style I was going for. These photos are taken before I sealed with high gloss mode podge, the liquid kind and the spray.
lilshrt4atroopr
I got my helmet a couple of months ago from the Mandalorian Arsenal (http://themandalorianarsenal.com/rebels.html) and I'm trying to put it together. It took about 3 months to receive the helmet so make sure you give yourself plenty of time. I think the helmet itself came in great condition right out of the cast so I recommend this seller.
I've only used my dremel a few times so it kind of looked a bit like a dog chewed something up the first few times but I'm getting better and way too stubborn to just give up.
The red stuff is bondo spot putty. I'm layering it up to fill in the valleys where my dremel bit off too much material. I used a tungsten carbide bit. The youtube video said to use a round cutter, that's probably what I'll do next time!
Here is a picture of my first prototype of Sabine's gauntlet. I have since found some pictures that suggest the lights at the bottom are in more geometric shapes. The light panel is from a really cool website called adafruit (https://blog.adafruit.com/2015/04/1...-4152015-live-2pm-et-guest-host-jesscalifano/). If you haven't seen this before it might blow your mind. The technology is called EL panel and you can also get EL wire from other sellers. I kind of want to put some EL wire in my helmet so it lights up like a commando. Really cool stuff!
lilshrt4atroopr
So I haven't updated this like I said I would but here's the finished costume as of Dragoncon 2015
uploadfromtaptalk1442098258055.png uploadfromtaptalk1442098282969.png uploadfromtaptalk1442098373968.png
But it's not done! I still want to make the adventure gear and I'm probably going to end up remaking some of the armor so that it looks a little less stiff. The aluminum looks great but it's difficult to shape. I still don't want to use foam! I think I might try using Sintra.
Sent from my SM-G900V using Tapatalk
