Here is the OWK with the static emitter option (there will also be a FX option)
This one copies the Original prop saber MR referenced for their replica. Which you can see on Star Wars online
During his years as a Jedi, Obi-Wan Kenobi fought with three lightsabers. His first had a blue plasma blade and a hilt similar to that of his master, Qui-Gon Jinn. Obi-Wan used this weapon until Darth Maul kicked it into a deep shaft on Naboo. He then constructed a new, blue-bladed lightsaber...
www.starwars.com
The control box is chrome plated resin cast from an original part. The rest of the saber is aluminum(except the control box card and covertec) and has been painted to match the original. Glossy grenade, satin booster. The neck is a 4 part paint process. It is hollow and can accept electronics. Sound vents under the pommel when the pommel is reoriented and a small gap between booster and pommel is exposed.
Although it is possible to FX this piece. It really is designed to be a static display piece that preserves the details of the original prop, warts and all.
