ROTS lightsaber Cast from Original Parts Project discussion
Anakin Starkiller
No, I would like one too.
Ironically, I've been trying to get this project sorted for year and have lost around $1000 dollars in paying for prints, molds, and prototypes.
The problem with doing runs of cast sabers is the startup cost it high because of mold making and then you need to have order sized in excess of 300 pieces in order for it to make the project worth it to the companies. I did the Maul saber, because you can cut that in half with two casts to each prop. But even doing so. I still have a number of Maul kits that haven't moved nearly as quickly as the Machined Aluminum FX kits I've done.
Dewy
Well the Obi TPM saber was cast from a static metal & resin/delrin hero prop... maybe we should follow this process and you should do another run of those...
thd9791
yea - I've been dying for mixed media prequel hilts faithful to the props or threaded rod embedded hilts, etc.
I don't think anyone is doing something like this and I'm in!
thd9791
also a super weird looking anakin hilt there... just an allen screw up front, a more normal looking red button..
Ghost neverdie
i think there were two versions of the ani`s graflex.That stunt`s T-tracks were more thiner than the other one.The design makes it easier for the actors to hold on.Maybe they only just change the size of T-tracks. :oops:
SethS
There's one with box flipped too.
Honestly the ROTS sabers were practically mass produced, stunts stood on for heroes, there's multiple editing gaffs-- it's next to impossible to track the props.
master jinn
Vote for ROTS Ani and Obi stunts. A replica of the Azarian Anakin “Skinnyflex” would be good too since it’s one of the props made for ROTS. There are too many shiny, chromed fx version of the Anakin and Obi Wan ROTS hero hilts floating around.
Anakin Starkiller
Something's going on with the grip section of this stunt that I could never figure out. I wonder if it might be reduced to 1.25" around the grips or something?
lock
I am in! I have a few FX hilts but not enough static hilts and to echo everyone on here, there is a lot of choice out there for these. I love the Prequel hilts as much as I love the OT hilts. I've been eyeing up your resin Maul and will definitely be picking up one.
I would love an Anakin Skinnyflex and an OWK made as close as possible to what was used on set. Maybe even a TPM OWK with a threaded rod in it.
I mean, first gen castings off the original pieces on a static hilt would be something really special to have!
master jinn
Anakin’s dueling stunt has a narrower diameter than the hero hilt with low profile rubber grips (four instead of six) and also a thin neck to make it easier to spin.
Ghost neverdie
I think maybe they change the control box`s size too.because when they fight each other,most time they hold the hilts and we can only see the two sides of the sabers.But i can sure the stunt saber T-tracks were lower than the clamp.And base of the photo,i guess they just remove the top of the t-tracks.
Anakin Starkiller
Pretty exciting to see that prop store will be auctioning off the very OWK ROTS prop that I've been interested in here. It's clear that this prop is a combination of aluminum and resin parts. I know the clamp section is plated resin. But, which other parts are resin (grenade? neck" booster?) is not 100% certain. Thoughts? I hope that as more pictures surface we can nail down some more specifics. If any prop shop people want to chime in... it's always appreciated.
  • 2020-10-19T230516Z_1646106212_RC2ZLJ942615_RTRMADP_3_BRITAIN-AUCTION-MOVIE-MEMORABILIA.jpg
  • 2020-10-19T230526Z_524001158_RC2ZLJ9U3D2K_RTRMADP_3_BRITAIN-AUCTION-MOVIE-MEMORABILIA.jpg
harrisonp
is that Peter’s costume from Hook over his shoulder? I’ve been trying to find good pictures of that for a long time. I searched their site though and it isn’t listed
Halliwax
Legendary Member
So wicked! I should have stuck with my oring so windvane color! Damn!
Second, I never seen on any other replica the windvane going up inside the emitter
