Mr Mold Maker
So, did you manufacture the components from solid aluminum? That’s be awesome…
All paint, imperial surface Alumaluster.
Yes. The openings are for the carbon brushes which are accessible from the outside of the hammer drill through maintenance hatches.So the openings in the sides are for the brush assemblies? (If this 627 diagram is similar enough)
Something tells me something else in the drill is used.. why gut it without any clues!
Dang, I meant people today identifying parts, like why crack open that drill in 2021 - but as for sourcing back then... that helps explain that as well, thank you!The way it was explained to me with most of these parts and most of the props is that they simply went to industrial surplus stores and bought various items they were there that they thought would be useful in building various props.
If you are not aware of what industrial surplus is or why items become industrial surplus, read this:
Surplus: Meaning and Primary Sources | Industries
ADVERTISEMENTS: After reading this article you will learn about the meaning and primary sources of surplus. Meaning of Surplus: Surplus or industrial surplus may be defined as those items/goods/materials which are in excess of reasonable operational needs of the enterprise/plant/concern. Surplus...www.yourarticlelibrary.com
So basically there is a high chance that the prop makers don't even know what the original item is/was used for.
