Volks
For Halloween last year I decided to do Hellboy. Got the RHoD made in around 10 days using foam floor mats and gap filler foam. Got me thinking about doing it for NYCC this year, but with a hand that is capable flexing. Saw some unfinished ideas already posted on here, and got some insight from instructables for the robotics, and going with a puppet approach was using more force than anticipated.
This is my build from last year:
Skeletal Structure Foam (Vert View) Foam (Horiz View) Carving Final
Final dimensions are (and yes I know they are huge, I'm taller than Perlman) :
Arm:
16 inches (40.64 cm) long
Bands are 10 inches (25.4 cm) wide
Forearm is 8 inches (20.32 cm) wide
Hand (measures are approx)
At tip of knuckles 12 inches (30.48 cm) wide
At base (without thumb) 14 (35.56 cm) inches wide
12 inches (30.48 cm) long
Weighs under 3 pounds (1.5 kg)
So as far as robotics are concerned I have absolutely no experience, but I plan on having the necessary components (minus battery packs) inside the hand. Rotation for the wrist will be created by the handle that will also control the fingers.
Arm:
