androidandy
It is only cheap because I picked up the Zero Halliburton briefcase at a thrift store for $5 a while back, but I wasn't using it for anything. It is made of aircraft aluminum and is gunmetal grey. The lock on it was damaged, but I thought about making one of those sniper spy cases with cut foam for the gun parts to be assembled in it. I came across some egg crate foam that is used in gun cases for free from some packages we tossed at work. So I decided to make a quickie case for my prop Guns. It took me less than an hour to make and it also has some BR connections. A silver or aluminum finish ZH case can be seen on Deckard's table when Racheal tosses the photo on the ground in his apartment. I actually ripped out the leather lining from it and maybe devalued it a hundred bucks (they sell for over $100 on ebay). but it is now a cool prop in its own right as well as prop protector. The guns I have in there are from left to right a C&S Coyle V3, and an early Coyle cast from a stunt gun. I may down the road use the custom cut foam 3 layer, but in the meantime this will work with different props as needed. Total cost $5...
