Questions on Iron Man helmet build
BengalsIronMan
Two questions 1.) Where do the ear pieces connect? I have the area where it goes built but can't figure out how to connect the 3-d piece. I have Pep Viewer up and keep clicking around hoping to find what it connects to but no luck. 2.) The side of the helmet (piece that connects to the back and just above the ear piece) doesn't really line up. Is this ok? Should I force it to line up or just make it good enough and touch it up in later stages? Thanks in advance:cheers
Ohhhhhh so there really isn't a way to glue them to the paper itself huh? That would explain why I didn't see anything on the model :D
Any idea on some pieces not lining up?
To be honest not a lot are lining up idealy. I'm sure it's my error in thinking "eh being off just a tad won't hurt I can refine later when I get to the sanding process". Thanks a lot for your help thus far I appreciate it
no worries buddy if you want to get a real gd line up use tape on the egedes and it will pull it together for the resin stage and body filler will do the rest :)
