I'm currently adding miscroswitches to my PR to work electronics, counter and sounds.
However as my PR is a cap firing one, there is very little room.
I need a super thin switch to go inside the Thompson. Also i need it reversed, so:
trigger is not pressed, the switch is pressed, and the circuit broken.
when:
trigger is pressed, the switch is released, and circuit is made.
So, ive found these in the uk, which are 0.25mm thick which is perfect.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P14169DKR-ND
However im not sure if they do what i require.
Can anyone give me advice on these? Are these like microswitches but flat? and do they wire up like microswitches? Just solder pos and neg wires to them? Finally if wired the other way round, does it reverse the function?
Thanks in advance!
lewis
when:
Thanks in advance!
lewis
