Predator Head building help needed!!!
Hellstrok
Before i get started there are a few things i need to find out...
First, if you make a mask out of Latex what do you use to fill in the empty space of the mask???
Second, what do you recomend i use for Dreadlocks? I was thinking Latex but i dont know how heavy of flexible that would make them.
Thanks for the help!
thicky ricardo
hey man you should definatly look around a bit,like in the huntorials or just use the search option plethera of info on this forum,but to start a mask sculpt you have to decide if it will be a wearable one or for display,(wearable =latex,display= resin) but all sculpts usually start with a clay sculpture,but to fill empty spots of latex u can use an upholstery foam, or a polyfoam but you will need a mannequin head,
Hellstrok
Thanks that helps a bunch
Its going to be wareable (part of a costume)
