Polyester Bondo on epoxy fiberglass?
Toxx
A basic question:
My Fiberglas resin is based on epoxy, will it work to cover it with bondo based on polyester?
Do you sand the epoxy coat before applying the bondo?
yeah, I use it on pep. I do it mostly to get the polygonal edges rounded and of course it helps the adhesion of the filler.
If anything, a light scuffing is enough for it to stick.
Ok, i will see.
Have to wait my epoxy to be cured, need about 24h, but is still a little bit sticky, maybe to much hardener?...
think i should go next time with polyester-resin.
In your videos you are using smooth-on 321, isn't it a PU-Resin?
Ok, i will see.
yeah, but I prefer expoxamite laminating Epoxy Resin now adays. I have a video for that as well.
Think you also live in an area with cold climate conditions where it is unconfortable at an "well aerated area" in winter. :love
Do you use a mouse sander or something for your scuff sanding after epoxy?
Epoxy is sometimes used as a primer on materials that can't stand polyester. For instance, many surfboards are made from a styrofoam core with a layer of epoxy and then covered with polyester-resin and fibreglass.
Ok, the epoxy looks really Sleek and glazed so is think I will sand it a little bit
