Painting on rubber?
DeLano80
I need to paint a white wall on 1/43 scale rubber tires. The two different sets of white wall tires I have found do not fit the car I am working on so I figures I need to paint, or replicate another way. Any advice?
I guess I was always under the impression that all paint, when applied to a soft rubber surface will flake off. I shall try the acrylics.
I would try using Pros-Aid which is a sticky liquid adhesive and mixing that with the acrylic paint.
I've heard of urethane paints doing well on rubber, but they're kinda nasty stuff from what I hear and you need proper equipment and ventilation for it.
You can mist a tiny amount of acetone through an airbrush which helps key up rubber surfaces for better paint adhesion.
