NeonNazgul
Greetings RPFers!
I've recently started this great hobby and would greatly appreciate any advice. I'll preface this by saying I really don't have a *clue* what I'm doing, but bolstered by the incredible work I've seen on the RPF I'm trying my hand. I've poked around here and YouTubed my heart out, but if anyone has some one-on-one advice that would be fantastic.
The project: Modding a Don Post Standard (Rubies) Vader mask.
The goal: New mouth grills, eye lenses, paint job
The why: A Tale of Two Vaders | NeonNazgul.com (my personal blog. Just for those interested in why on earth I'm bothering with a Don Post Standard)
I've pulled the lenses out and popped out the nose and tusk caps no problem. Using a Dremel I've started cutting out the plastic grill between the teeth with the ultimate goal of putting a nice metal one back in.
The issue I'm currently facing is the injection-molded plastic (a vinyl I believe but please correct me if I'm wrong) is sanding roughly. It's tending to roll up into filaments and give ragged edges. I'm using 220 sandpaper and small sanding sticks of similar grain. My process so far is this:
1) Core out the bulk of the material with the Dremel
2) File down the rough edges with a needle file
3) Sand the rest of the way
The results aren't *too* bad but i can foresee problems. Here's what the first cut-out looks like:
At this stage I'm wondering if anyone has sanding advice for this sort of material. I'm having some difficulty getting clean edges, and preserving sharp lines and angles -- the right angle at the base for example, is getting a bit "mushy". Any tips & tricks I should be aware of?
As I said I'm totally green at anything like this, so any advice is greatly appreciated
Thanks for you time folks.
