I made this because in the show it obviously looks like it should open. I decided to use off the shelf hinges and magnets so it could be easily assembled by anyone.
Right now I only have 1 size (size 16) which should fit over a glove .
The compartment inside is 15.5mm x 12mm x 1.2mm deep. So you could put a micro sd card in it or make a micro flash costume.
CLICK HERE TO ORDER THE BASE
CLICK HERE TO ORDER THE REVERSE FLASH TOP
CLICK HERE TO ORDER THE REGULAR FLASH TOP
Here is the magnets you need
Here is the hinge you need, select the 06mm from the drop down menu
Have fun with it.
Rob
Have fun with it.
Rob
