Sean Bradley
I was wondering if anyone could help me with a material suggestion. I'm starting work on new costumes that I need to cast some foam rubber parts for. The parts are bodysuit/armor items, not prosthetics. I'm looking for a castable foam rubber that is fairly stiff, but maintains a modicum of flexibility, approximating the density of EVA foam but in a castable form. Ideally the foam should be 'skinned', to not have an open porous surface on the cast parts. I'd also need to be able to color the batches and/or paint the material after casting.
I've looked into Smooth-On Flex Foam, which was very promising, but I wasn't entirely happy with the firmness of the cast parts. The surface seemed a little too soft and floppy, and didn't seem to take abrasion well. Also paint had a tendency to flex and crack because the material was this soft and stretchy.
Could anyone recommend a material that they've worked with that has the properties listed here?
