Need input: Batman Cryptographic Sequencer
Discussion in 'DC Costumes and Props' started by Jawafive, Jan 22, 2012.
  1. Jawafive
    Jawafive Sr Member
    1,681
    So the next batman gadget we are looking at producing is the cryptographic sequencer. Below is the 3d model that will be used for printing. We are trying to find an economical way to get the cover to move as it does in the game. We've discussed buttons, but I'm not sure how to proceed. I welcome any input and/or ideas. As it is right now the piece is about 10" long and can accommodate your favorite smartphone where the screen is. The final product MAY be scaled down, however.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I would really love some advice from anyone who thinks they can help. I'll repay you somehow or another if it works!
    -Matt
  2. 88reaper88
    88reaper88 Active Member
    341
    Thats crying out for an Ipod touch/iphone and app.......
    As for the hinge, surely a simple bolt would do the trick? Maybe even just a bot of dowel rod?
    Looking forward to how this comes out.
  3. armorture
    armorture New Member
    17
    rewiring the guts from a PSP would look pretty cool. especially with the joystick placed accordingly. As for the hinge, a simple pin/bearing system would make it move smoothly.
  4. vtswordfish
    vtswordfish Sr Member
    1,306
    Yeah for real, set it up to take an Ipod touch/iphone or something, that'd be sweeeeeetttt
  5. daryllwin
    daryllwin New Member
    2
    Don't forget us Android users!
  6. Jawafive
    Jawafive Sr Member
    1,681
    Well, I'm an android User too so you're not getting left out!
  7. rensole
    rensole Active Member
    330
    actually might want one :p looking sweet =D
  8. Jawafive
    Jawafive Sr Member
    1,681
    Yeah the model is just stellar. I couldn't be more pleased with it, but we just need to figure out that next bit and all should be ready to go.
  9. VinXero
    VinXero Active Member
    341
    How about two pieces? One that can have a painted on display and then have it removed to another one that can hold an android phone or iphone.
    It would be three pieces total with the handle staying original ofc.
    That would be awesome.
  10. Jawafive
    Jawafive Sr Member
    1,681
    I think a bolt could be a good idea. May just have a recessed area for screws to be glued in and then bolt from the other side. I thought about two rods sticking out from the face place, going into those two slots, and then some sort of cap that would secure in place.
  11. Nobby
    Nobby Sr Member RPF PREMIUM MEMBER
    2,261
    for the hinged part:
    how about some long chicago screws with cover plates to conceal the heads?
  12. Jawafive
    Jawafive Sr Member
    1,681
    Oh now that may be something that can work!
  13. Nobby
    2,261
    did I help ? :D
  14. DrewSmith007
    DrewSmith007 Well-Known Member RPF PREMIUM MEMBER
    967
    If you can modify your 3D model, you could add a snap-fit post and a mating hole. I'm trying to find an example, and one that springs to mind is the method used to attach pinwheels to their post.
    EDIT: Well, I can't seem to find a good image, but it's the same joint that LEGO uses for wheels. KNEX uses it too, I think, for all sorts of things.
  15. Nobby
    2,261
    I think chicago screws are the way to go............. :D
  16. DrewSmith007
    967
    Probably easier and definitely less breakable.
  17. cboath
    cboath Master Member
    3,276
    On chicago screws, the basic idea is that it's two screws that screw together, so basically you embed on screw on each side and tighten just enough so you can still rotate the pieces, correct? If that's it, i've got a great way to hide the screws...
    A second issue with rotating the cover open is that, in the game, the top part just moves through that square plate on the bottom right hand side of the base. That plate is about 1/8" high. I had thought about making it a push button that clicks into place. Push it down, and the top can open. Close the top and push the button in to help hold it in place. The piece doesn't have to be functional, but the only other option is getting long enough screws that there's 1/8" (or so) leeway to raise the top. In the game, it does raise up, but barely 1/32" (less than 1mm for you metric folks :) ).
  18. cboath
    3,276
    On the smart phone option....
    It just so happens the opening is large enough to hold an iphone 4. Anything that size or smaller fits just fine right now. Here's the issue with other phones - sizes. There are LOTS of different phones out there with different sizes. I believe the iphone 4 is 4.25"x2.25"x.25" (those numbers from memory, so they could be off a bit). I measured mine it when modeling that area. I know there are larger (length, width, and depth) phones out there.
    As for phone or static display, a phone setup could easily hold a static display. You'd just have extra depth under whatever you use as a panel.
    In the end, for either setup, there will be a plate that covers the phone and sits flush with the surface (probably screwed on) to make it look like the screen is part of the prop. The plate has not been created because the size of the hole/what goes in the hole/etc hasn't been decided upon yet.
    If you're interested in sticking a phone in it - measure your phone. If you don't have a ruler or tape measure, look it up on your manufacturer's site - hopefully it'll say. I don't have access to other phones so I can't measure them. If sizes come back larger than the iphone 4, i'll have to see exactly how much space there is to work with.
    The actual area where the screen sits and is covered by the top is:
    (the left side is arced in a bit at the top if you can't tell)
    Across the top (4.5")
    Across the base (4.7")
    Height (2.8")
    Plus, to have a cover plate, you need to plan on a bare minimum 3/16" border as well.
    Those 4.7-5" screen phones that are out there probably won't work.
  19. Jawafive
    Jawafive Sr Member
    1,681
    Lots of good input, I think chicago screws are going to be the way we go!
  20. Talisen
    Talisen Sr Member
    1,682
    For the holding closed - even some small earth magnets to hold it closed? Could potentially have one set in the open position too.
  21. Knowone251
    Knowone251 Well-Known Member RPF PREMIUM MEMBER
    666
    How ever you end up doing this i want one!
  22. eko2184
    eko2184 Member
    191
    Excited to see how it turns out!
  23. cboath
    3,276
    Current status shown below.
    It's all set up to take an iphone 4. Nothing bigger will fit, period. I had to stretch it a bit in order to take the depth of the iphone.
    Present set up will make use of a chicago screw. We just need to find one about 1//8" in diameter (a bit large would still work, up to 1/4") that will span a bit over an inch, although that's tweakable a bit either way.
    The chicago screw would obviously insert at the pivot and a cap can be placed over the screw to simulate the right side control you use in the game. the left side control is etched on the left side. There's a matching cover plate on the bottom to cover the bottom screw as well.
    Even the raised area on the right side is usable - a matching hole is cut into the bottom of the top piece to hold the unit in place when open.
  24. Survivalist
    Survivalist Member
    181
  25. JazzK
    JazzK New Member
    3
    I think I might want one of these!
  26. Jawafive
    Jawafive Sr Member
    1,681
  27. Bonded Hawk
    Bonded Hawk Well-Known Member
    566
    Too many other things going right now, but I love the grapple I got off you. Any rangs in the future?
    Bonded Hawk
  28. Jawafive
    Jawafive Sr Member
    1,681
    I am hoping that batarangs are in the near future!
Share This Page
