I am making a cosplay prop and i need some help. It will be a large ice shard blade (images below) I was thinking of making a positive using foam then covering it with packing tape then release wax then resin coating it. That is my plan but there are several things that can go wrong. I plan on using acetone to melt the foam inside the Resin leaving a hollow resin shell but i am not sure if acetone also affects resin too. Most Resin is too thin for this and will just run off when i try to paint it on to an object. Is there any kind of resin that is thick enough to be painted on with a paint brush and not totally run off before it sets?
Am i going about this all wrong? is there a better way to get an hollow resin shell to look like the images below?
