Re: NEED HELP!!!!!!!!!!!!! WITH IRONMAN HELMET..small grooves...any advise would be g
i printed an extra set of pepakura pages to use as a template for mine. I drew them on in pencil following the curve of the template paper. Then i used the dremel to start the groove (I cut very very shallow). After the groove was started I have been using detail files to make it deeper and wider.
if you pick up the diamond coated cutting disk for the dremel you can use that to cut your very thin starter lines because the disk is made of thin steel, not fiberglass. i definitely recommend finishing the grooves by hand as it is far too easy to slip and ruin your work
