Need Help ! Ultracal 30!!
nighthunter
Hi Hunters´s!
I need a little bit help to find a good alternative for Ultracal !
I live in Germany and we have have no Ultracal 30 here !
So i need some technical Information´s about Ultracal !
I found a Dental Plated Plastic Plaster ( Whuu what a Word !! )
In the hardened condition laid 320Nm !how strong gets ultracal??
can someone help me?? Greetings
Hi nighthunter.
Schon mal bei der Firma Kaupo nachgeschaut dort beziehn wir unser Materiel.
www.kaupo.de
Regards
From Seligenstadt
I am assuming you are using the Ultracal alternative for casting latex masks or other items?
If yes, then dont worry so much about how tough a material you need. What you need to look for is a Porous (spellcheck) material.
The ultracal30 is best becuase A. It absorbs water due to it nature. and B. It is super strong meaning the detail and such lasts longer.
Keep this in mind when looking for a material. It needs to be able to absorb water From latex, leaving you the negative from the mold.
@ Meangene
Yes i search something to cast my Torso in Latex and the only stuff i found right now is that kind of Dentalplaster !
They say it is very strong 320Newton the mm ! my only question in the Moment is : anybody knows how strong ultracal get when he dry´s ??
I know that Dental Plaster is used in miniatures a lot.
If I'm reading this right, Dental plaster is a Hydrocal. I use a Hydrocal because I don't have a local source for Ultracal 30. Hydrocal can have a lot of different additives to it to act different when needed. The different versions would have different dwell times because they will obsorb water at different rates.
But if it has a plastic in it, it won't work well. It won't soak up the moisture from the latex.
I think if you wanted to use it you might want to get a small batch to test it. It may work.
@MasterAnubis I think thats right what you wrote this stuff won´t absorb the Water in the Latex !
here is it Tecnical Information in English i put it in the Google Translater ! Thats the #1 what i found !
Quick Rock 20 kg
Highly thixotropic, plastic-finished die stone
nachISO 6873: 2000, type 4, CAD / CAM suitable
Applications:
For master models, sprockets and denture
Standard Colors:
Golden brown, ivory, apricot
The advantages:
* - Resistant to water-based impression
* - Highly thixotropic flow behavior
* - Quickly removed from the mold plastic surface coating
* - Smooth surface
* - Extremely stable edges
* - Excellent value for money
Technical data:
* Mixing: ..... 100 grams: 20 ml of powder / dest. Water
* Mixing time: ........... vacuum: 30 sec
* ................................. Manually: 60 sec
* Processing time: 6 min ...... -7.
* Mold removal: min .......... after about 20 -25.
* Brinell hardness after 2 h: 300 .. on N/mm2
* Brinell hardness after 24 h: over 320 N/mm2
* Expansion after 2 h: .... at 0.09% expansion after 24 h: at 0.09%
Quick Arti kg 20
Synthetic gypsum articulation
Applications:
For the precise assembly of models articulator
Standard Color:
Extra White
The advantages:
And here is #2 he is not so strong !
I remember that Mannowar wrote to me that he mixed Hemp under the Plaster to make it sronger! But the first Problem is the Plaster !
* - Increased adhesion
* - Effortlessly articulating
* - Fast setting, installation of several possible models
* - Creamy - it was clear
* - Low expansion
* - Express Next working possible
Technical data:
* Mixing ratio: 100 g: 30 ml of powder / dest. Water
* Mixing time: ................ vacuum: 15 sec
* ....................................... Manually: 30 sec
* Processing time: ............ 2 - 3 min.
* Mold removal: min ................ after about 20 minutes.
* Brinell hardness after 2 h: 50 N/mm2 on .......
* Brinell hardness after 24 h: 60 N/mm2 on .....
* Expansion after 2 h: 0.03% below .........
* Expansion after 24 h: 0.06% below ........
