Need help engraving lettering
Wes R
Legendary Member
I'm getting ready to finish my M41A grenade and need help figuring out how to put the detail info on the bottom of it. The bottom is a piece of sheet styrene and I'm not too sure about holding my hand steady with an engraving bit in the dremel. I thought of maybe a water slide decal but that's a big cost for one project at the moment. Any ideas are appreciated.
lol. It's basically the type of decal you get in a normal off the shelf model kit where you get it a little wet to activate it and then gently slide it onto the project before letting dry and/or putting a setting solution on it. I'm not sure how available they are in your country but you can order entire sheets of the stuff to print out on your inkjet printer.
This thread is more than 13 years old.
