Need help 2 aluminum parts stuck together- can't get loose! prop ruined?
Anakin Starkiller
So I bought an Anakin AOTC lightsaber recently. It arrived today and I took it apart because I wanted to upgrade the shroud. I tried my new shroud on the saber and found it was too tight, so I tried to take it off and now it wont budge. I've tried everything and the two parts feel like their weilded together. I think that the biggest problem is that the main body was warm when I tried to put the shroud on and then cooled and now the two parts might as well be a single piece. Can anyone help, the saber is essentially ruined as is. Is anyone here excpetionally strong with a grip of iron?
Please:cry
Dan Stokes
DDStokes@aol.com
So 2 minutes after I posted the last message, our X-mas tree fell down and broke alot of ornaments. Not a good night.
Get some dry ice... and you should be able to lightly tap off the shroud.
Thanks for the advice. Can you tell me know this works? Does the aluminum shrink with the cold or something? The reason I ask is because I want to be prepared before I try this. Also, can I handel the parts exposed to dry ice? And will the dry ice harm the pieces themselves?
Thanks a bunch
Dan
Don't touch the cold metal with bare skin ... wear thick gloves.
Before investing in dry ice, try putting it in a freezer ... might be enough to do the trick.
The reason it works is that metal shrinks (contracts) when cold. I work in a large shop, and we have some assemblies with friction fit; a bored hole acepts a part with a larger diameter ... the only way they fit together is by warming the body (at LEAST room temp) and freezing the inner part (we use liquid nitrogen). Freeze the inner part, and they go together. A few seconds later, the part is IN ... if it didn't go in right, there's a lot of time and money in rework required. ;)
Good luck,
ATM
ShackMan
As shackman said try the freezer freeze it for a few hours, and if possible once removed hit the outer piece only with hot water warming it faster then the inner stuck piece... The expansion and contraction should allow you to separate them...
Dry ice is better but I would try the freezer first...
Good luck,
ATM
ShackMan
It sounds like that is essentially what I did with my two parts. Except I don't have "a lot of time and money" to rework it.:unsure
exoray. Thanks for the info. I'll try that approach.
Dan
So, I tried the freezer and I tried a mizture of freezer and hot water, and neither seem to work. This thing is really on there and I don't know how I will go about getting it off w/o ruining the parts.
I'll try dry ice, but my fear is that as I freeze one part I'll freeze the other and so as the aluminum in both parts shrinks they will remain locked together.
Dan
How about adding a little 3 in 1 oil to the spot where they meet?
Let it sit for a few minutes and then try oulling them apart? Be carefull not to get the oil on any part you might need to grip.
Occasionally I've used aluminum tubing as a stunt saber blade. If I'm having trouble removing the tube from the hilt by pulling straight out, I've been able to remove it by twisting while pulling. Perhaps putting the shroud in a padded vise and try turning it out?
Have you tried tapping lightly with a rubber mallet? Or... if there's little space for the mallet to make contact, you can use a piece of wood between the saber and a regular hammer.
Have you tried a heat gun on the outer piece to expand the molecules to loosen it up. I have a similar problem with 2 pieces are polycarbonite so that method is a no; but with metal it should work. Just wear some good gloves.
