My first Cannon
quico 40
Just following instructions
Sorry for the pics
Air Elmo66
Nice Job Dude. How do you get the foam to have that texture like on the barrel. Did you buy the foam like that or you used something? What kind of glue did you buy. I bought foam last night to do the same.
ONE END
That is an excellent job! You know I tried doing this and Failed! I dont think I had the correct construction foam...
"round of applause for you"
quico 40
I used a floral foam on the barrel is like balsa foam ,color green or brown i get it in Michaels is very soft and you can cut, drill it very easy , and mold it with your hands ,for the cilinder i use styrofoam white then i cover it with acrilic gesso for harden it , and glue it. Glue.- I use "Hold the foam " ( micheals ) you can try with hot glue.Im going to do another with styrofoam white and cover the barrel with Ceramic Stucco Texture Gel " Liquitex I use it for made model bases " is very light ".
quico 40
Use a floral foam ( Hard one, white color ) you can cover it with ceramic stucco for get a smooth
surface :D
Air Elmo66
Im going to do mines starting today. I will post pictures up. Thanks man....
TUSKY
Foamies strike again!!
Thanks for sharing this great cannon.
I am in the process of trying too decide if i should make a cannon for my suit.
Well i am impressed so looks like i'm making a cannon too,..... :D
