my first Bio helmet build Armature questions
Nickolos
hey guys this is going to be my first bio attempt and i was just wondering if yall had some tips on the armature for it thanks alot
P.S this forum uses some lingo im not quite sure on like im assuming P1 stands for predator 1 design like with arnold and P2 is danny glover design or am i completely off thanks for your time
xdmray
howdy ho,
so you are going to sculpt a bio and you need an armature?
i made my armature based off my half mask. it's kinda the way you want to go. that way you know it will fit your mask.
i placed plastic wrap over my half mask and then put a thin layer of plaster strips over it. i then took off the plaster strips and and bulked it up on the underside. i then covered the thing in fiberglass resin so the clay would come off it easier.
you can see my armature in this thread
http://www.thehunterslair.com/index.php?showtopic=15792
and yes P1 stands for the pred in Predator and P2 stand for the pred in Predator 2
cheers
Nickolos
and id love too do a mask or even a half mask but i just dont have the time or the money right now id love to buy one of your half masks but im strapped on cash but ive wanted to do a bio helmet ever since i like 10 lol so i think i might just have to do a generic armature then if i ever get some breathing room on cash to work on a mask thatll be the first thing i do
xdmray
well then your best bet is to eyeball it. normal bio dimensions are about a 12 inch wide crown and about 20 inch from tip of crown to chin. but if you want it to fit a mask, its better to have the mask. otherwise you wll be designing a mask to fit your bio.
i would make a smaller bio type shape with cardboard for a base. use a great stuff expanding foam in the underside, and then cover the cardoard with fiberglass resin. now you have your base to put clay on.
good luck
EDIT:
just thought of another idea. if you do pepakura you can get a bio file and print that out in a reduced size and make you armature out of that instead. still doing the foam and glass though.
Nickolos
thanks man that was exactly what i needed thanks for the help i appreciate it and by the way your noland sculpt is sick bro
Nickolos
but im thinking ill just make it a display bio unless i can find a super cheap half mask if you know anybody that has like a damaged one or a bad paint up on one thats selling it cheap thatd be awesome
Nickolos
dude yeah man found out about that like last week i was going to ask you some questions about it and its size this program is so awesome but thanks man
