chubsANDdoggers
I can't place the scope... have you started making your own, Chubs?
Yes and no. I mean I’ve always been making my own scopes [emoji106]
Mine are just not metal..
But that scope in my previous post is actually Field Marshals..
Marcos22579
I found this poster at a local store.
The blaster has no numbers on the gun sight. The screws on the scope base are allen as in the TFA blaster and the handle doesn't have the amount mount of liines as in the TFA or ANH . The scope has no internal theads and the right side is the same as in the Masters Replica built.
The gas cylinder is silver metal and the droid caller and square greeblie (battery pack for blaster) looks like casts plastic.
Any thoughts on these finds?
Sent from my SM-J700T using Tapatalk
chubsANDdoggers
Any thoughts on these finds?https://uploads.tapatalk-cdn.com/20180428/b50e62f3f7866878e0b44c6951b03bef.jpghttps://uploads.tapatalk-cdn.com/20180428/be57c8ccd2f731bf896cd2653723035e.jpghttps://uploads.tapatalk-cdn.com/20180428/57dbcc98d0bc9393f8ea00ec5d04ab9a.jpg
https://uploads.tapatalk-cdn.com/20180428/32337c7dfa3bf5e010a4b5257be18186.jpg
This is a great find! Thank you for sharing! When u mention the right side did u take any pictures? I’d love to see the mount. Still haven’t seen any good shots of that side just yet.
When u say no numbers on the sight are u referring to the scope wheel?
Marcos22579
The scope wheel is brass on top black on the sides with 1-10 numbers. The gun sight leaf has no numbers like on the Masters Replica.
What I meant for right side was the fix plate. Similar to the TFA airsoft fix. There is even a blotch that looks like a bad sand job on the fire selector hole.
The handle has 11 to 12 lines or grooves instead of the correct amount as on the ANH built.
The trigger safety is the same as the TFA, with a thru hole.
Finally there are the screws that look like allen key and the rear sight that has no threads.
The pictures are not the best. The store had an overhead light that made a lot of reflection on the banner plastic. But the gun was oversized and the details I am pointing out were visible at plain sight.
Halliwax
Legendary Member
You would think they would just use anovos stuff wouldn’t that make sense?
Already made, pretty accurate...
I wonder why thy result to making things from scratch still
Marcos22579
I havn't seen an anovos DL-44 blaster but the belt holster and greeblies look a lot like the stuff they make.
I am very pissed with the Blaster changes from TFA and now I am starting to hate this Solo Movie "new blaster" even before the movie is on cinemas.
