Hello everyone,
It's been two years since I had the urge to do it, but I finally started making my own Spider-Man costume! This thread will be updated really slowly since school just started. But I plan on having the suit finished before Halloween.
Info on my print:
- Modified Ken's free ASM2 Pattern used
- The New Blood's Bagley symbols and blue color used
- Printed and assembled by ZentaiZone
Here's how the print looks.
View attachment 367177 View attachment 367178
I tried taking the pictures in natural light, but it turned out too bright.
Here's how the front looks with incandescent bulbs and after eating. :$
View attachment 367179 View attachment 367181
Here's a better picture in natural light. I really like how the bricks look.
Supplies I'm using right now.
- High density furniture foam
- Tjack's Faceshell and Lense
- Pepakura cardboard faceshell.
I planned on using the foam for the faceshell since it's a little big for my head. But that idea was a bust. Tjack's faceshell is just too big for me.
So I made a cardboard faceshell using JFCustom's pep file. That faceshell didn't turn out the way I want either.
So I just made the regular Gimpee faceshell.
This turned out really well! I just need a way to strengthen it.
Did some testing using the wood glue method from the
405th forum. I used whatever I had laying around my garage: Loctite Wood Worx.
At first, I thought it didn't work because the cardstock would just become flimsy and not strong. I gave up and was looking for another method for hardening/strengthening, but when I checked on my test sheet and parts, it became pretty tough. It just needed extra time to dry.
Test part. I threw away my test cardstock since I broke it doing stress tests.
Here's my faceshell reinforced with an unnecessary amount of bamboo skewers. I didn't want to risk any warping since the glue is mixed with water. Water + Paper =
BAD!!!
Supplies and prepping the glue.
View attachment 369420 View attachment 369421 View attachment 369422
After about 10-15 minutes, I finished the first coat for the.
I waited about 1.5 hours for the glue to settle. I then applied a slightly thicker second coat. I'm going to wait until sometime tomorrow to add the final layer and then let it dry for about a day. Then I'm going to remove the bamboo braces and do about 2 coats inside the faceshell.
I finished up the coats of wood glue. It warped around the eyes a bit, but that's my fault for not gluing on the eye frame supports.
I also filled and smoothed it out with wood filler and primer/filler spray paint.
I didn't really bother with getting it perfectly smooth since it's pretty much unnecessary.
Here are some pictures my brother took of me wearing the faceshell. We didn't bother centering the mask since we were just testing.
View attachment 373911 View attachment 373909 View attachment 373910 View attachment 373908
You can see that in some angles you can see the faceshell.
My solution: Cast the shell and form it with plastic!
That will probably be a whiles away since I have to get casting/molding material. And on top of that, build a vacuum former...
I finished the vacuum former earlier this week. I have to say, I'm pretty impressed with the outcome!
Here's a small test I did with a ball bearing toy. It takes the shape really well!
Now that I know it works, I need to buy some casting/molding material and some larger plastic sheets!
I covered the eyes on the shell and used drywall spackle to make it a little more round.
After I got the supplies, I created the mold and used hydrocal(plaster) to cast.
View attachment 394181 View attachment 394182 View attachment 394179 View attachment 394180
This thing weighs a ton!! I used a chisel and sand paper to lessen the size of the nose. I also made the head more round.
And I reached the image limit.... I should have made multiple posts...
